Wilwood Brake Kits 260mm and 275mm
ep71
63
Ireland
275mm and 260mm brake kits to suit 13" - 15" wheels
Kit consists of
2 off Wilwood Dynalite calipers
2 off Drilled and vented discs (grooved only discs $50AU extra)
All mounting brackets and fitting kit
Brake pads
Braided stainless steel hose kit
Tech:
257 x 23mm disc for use with 13" wheels
approx 300mm clearance required
275 x 25mm disc for use with 15" and some 14" wheels
approx 320mm clearance required
275mm kit may require slight trimming of the lower control arm depending on LCA and roll centre
Replacement parts
Discs: $65AU per side
Pads: Wilwood (as per kit) $50AU, Mintex M1144 $105AU, Ferodo DS 2500, $160AU
Fitted:
Price: $610AU per kit
Shipping: Approx $100AU
Please note, prices are subject to euro exchange rate so may fluctuate slightly, please contact me for an up to date quote
ep71
63
Ireland
we had a load of the gold coloured brackets left over from a previous brake kit so it was convenient to use them. 12.9 grade socket heads, just used the hex bolts on my own car as i was waiting on the correct length socket heads to come in
