Fuel economy for 4ac and 4ag varities
Julz01
713
Hey guys
thought with the current petrol prices that fuel economy is a key think in getting the most out of our hard earned money. Im currently wondering what people are getting to a tank with their setups. And also how much does the tank hold as I think its 25L but could be 30L adm tank.
At the moment I get about 220-240km per tank, Not sure if thats good or bad for the 4ac with normal unleaded
what do you guys get and what tricks do you use to get more out of your fuel
amulday
178
Central Vic.
www.citystoppers.com
Engine - 7 Rib Big port
Mods - Pod filter, extractors, plugs/leads.
Fuel line - Running the 6mm adm fuel line.
Fuel Consumption - Before I changed the fuel filter I was getting anywhere from 220~370 km/tank depending on the driving. Seriously after only changing the fuel filter on mainly highway some city I'm seeing above 500kms a tank EASY! I couldn't believe it but it's been about 8 full tanks and still getting kick arse km's. The fuel filter I took out I cut in half, was absolutely caked in thick brown sludge.
Stain
Nov 22, 2006
1,474
Cairns
My car has a 40l tank... I don't know its ful history but its a ADM Sprinter?
I get about 440km to the tank, so thats 11km/litre... not bad when I frequently drive with a lead foot.
Mods include;
Bigport 4AGE with lift pump in tank and a high pressure pump. Stock lines and injectors.
Julz01
713
Yea Im not sure, It might be my petrol gauge beacuse when it gets to about 3/4 empty I can put in about 22L or so to fill it up, So Unsure maybe my gauge is way off, think I might just drive it around till it goes completely emptyn with a jerry can and see how many km I get out of it.
Anyone got a definant answer on the Capacity of ADM/JDM tanks
Stain
Nov 22, 2006
1,474
Cairns
I drove mine into the petrol station after the fuel light was on for a good 20min... and I got 39.8l in there when it clicked.
25-30 lol
Try stock ae86 tank has a internal capacity of 50ltrs.
I have bigport stock everything even the ecu, was rebuilt with fresh rings and bearings about 120,000kms ago.
I constantly still get over 500kms per tank, even after the 4.5 was put in.
Ive had it over 600kms before. That took 45ltr to refill.
Richard
Dec 9, 2007
2,602
122
Central Coast
my fuel gauge does that its like my car drinks the 1st half the tank in like 100kms but the 2nd half will go for another 300 atleast (i never let it go past 3/4 empty so not fully sure)
Julz01
713
Yea that would explain the problem Im having then, I keep thinking its going to run out but fulling it back up when its only half way thats why I only thought it had 25-30L
As well I never realised that the ae86 had a petrol light lol :oops: when does it normally come on and how many km can you get before there is no fuel at all?
PETE
Jun 1, 2006
2,319
Newcastle
royaldrift.cjb.net
wells ive got the ae82 bigport and it gets bout 7litres per 100kms.so i can easily get 600+ out of the 45 litre tank.
with the sprinter its a ST 20v running microtech and exhaust.its bout 9.6litres per 100. so just under 500kms to a 45 litre tank
this can vary.. see when i had the 4ac, when the petrol light came on first time i had between 10-12ltrs in the tank.
when i converted to 4age, i had a new intank pump, and my old fuel sender now when the light comes on i have about 5-8ltrs
the 4ac with 10-12ltrs, i could get almost an extra 100kms, with the 4age with 5-8ltrs i might get 30-40kms..
my ae86 used to burn 35 liters in 250~ k's
smallport 4ag
ae101 quads (no airbox)
adaptronic ecu
288° cams
metal HG with skimmed head
4-1 headers
no o2 sensor
no cat
60mm straight TODA exhaust
85kW atw
86Beers
138
Adelaide
The fuel tank is definitely 50litres!!
I believe the warning light comes on with roughly 10litres left.
I get 13-15km/L with my gze (3sge throttle body, fmic). I get told my odometer is out of whack when i say the mileage i get! I know my calculation is good as i have driven the exact same route to work with a near new car to get a correct distance.
The fuel efficiency and the power of the gze are unbeatable :D !!
roadsailing
548
oh wow, so much misinformation in here!
sprinter tank is listed as 55 litres in the manual, but 50 i will believe too. When the fuel light comes on you have about 15 litres left or so.
Highway kilometers i got 6.2 L/100ks out of my 4AC, with the 4AGE it is definately worse, around 7 litres per hundred from memory.
240 ks out of a tank wiht a 4AC is fucking shocking! i have done 600 ks on a tank easily
sgroie
Jul 31, 2008
16
i only get about 239km out of tank on my 4ac. its only got a an exhaust nothing special just replaced the old rotted one. currently in the middel of a 4age bigport swap. im interested to see if it will improve. i hope it does :| .
Stain
Nov 22, 2006
1,474
Cairns
After going from 3.7 up to 4.1 my car has improved!
Because the thing is so damn noisy on load I'm coasting everywhere, lol.
741
272
Bergen - Norway
www.rad-GTV-ski.com
my AE111 BT 20V gets on average 7.2/7.4ltr/100km city driving, this is not pussy foot driving but lots of high rpm/large throttle openings. On the highway I can get it down to 6.0/6.2ltr/100km sitting on 110km/h. I reckon with a little pussy footing I could get it just under 6.0ltr/100km on highway.
