Coolant leaking issues
regginblack
273
melbourne
Hey guys, Im having issues working out the name of the part that is leaking and where to source one from. Its the two metal nipples that are behind the water pump that connect to hoses which in turn connect to the throttle body. mine appear to have rusted away near the bracket and is leaking coolant when i drive. are there any simple fixes? and if not where can i source a new one from?
Post a pic and we can go from there.
Id assume you have already sussed out using more goop?
Welding is an option these days
Julz01
713
Im assuming that this would be the pipes for the cold start, on mine instead of metal its just rubber, just chop were its rusted and then use rubber piping instead.
post a picture up so for a confirmation though
